Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
910 Questions View all
Why wont it work past the apple logo?
Hello. so i dropped my ipod and now when i plug it in, all that shows up on the screen is the apple logo flashing on and off. i cant even reboot it. it also wont turn on at all when its not connected to a computer. is there anyway to fix this?
Add a comment
1 Answer
Chosen Solution
ana, first try to place your iPod in diagnostic mode. It is a bit tricky and you may have to attempt this a couple of times.Take your iPod and place your right thumb on the center SELECT button and your left on the top MENU button. Press down both thumbs for about 6 seconds until your iPod reboots. Immediately move your left thumb around to the rewind button |<< on the left and hold this down together with SELECT for a further 6 seconds. Your iPod should now switch into Diagnostic Boot mode. Run the diagnostics and see what you get. Unless you are using a firewire cable, it will give you an error on the FW. That is okay. Once the test is done press SELECT & MENU for 6 seconds to reset the iPod again. You could also try to place your iPod in disk mode and see if your computer recognizes it at all. This link will show you how to access disk mode. Should this not work, disassemble your iPod using this guide. Check for any loose cables, connectors or any broken parts. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
ana will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 2,057
