Non-Unibody, Core Duo & Core 2 Duo Processors
454 Questions View all
Can this model of older MacBook Pro be upgraded to Lion?
I have an older model macbook pro (2.16 GHz (Core Duo) MacBook Pro 17") and I'm not sure if it can be upgraded to the Lion OS.
Also, the computer took a nasty fall a few years ago and tweaked the upper and lower body frames a bit - not the computer overheats badly if I don't use a multi-fan cooling pad and a 3rd party internal fan control app...would getting new upper and lower body shells fix this?
Thanks!
Damon
Comments:
Thanks Stefano!
by
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
You can easily do the Lion. You need to have a beta version of 10.7 so you can get into it and change some code so it thinks the processor is a Core2Duo. Even on the iMacs that I've have upgraded the processors from Core Duo to Core 2 Duo, I have since gone back in and downgraded to 10.6.8 because they wer slow and just didn't run right. I don't recommend even trying.
Score 5
Comments:
Furthermore, I don't know what your situation is, but I still have to work with a local Intranet whose requirements include "A PC with Windows XP or later, or a Mac with 10.6".
So, legacy does still exist, and Snow Leopard has still a niche. I just hope every legacy will find a replacement...
by
Add a comment
Add your answer
Damon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,087
