Stoled startup in white screen with the grey apple.
The unit had its hard drive formatted, after which it now freezes when booting from CD. The unit powers on with a chime, CDs spin up, but the laptop never progresses past the white screen with the grey apple. I had hoped to perform a few more tests on this unit before listing it, but I do not have the expertise. I reset PRAM, SMC without success. When holding down "Option" during boot, I found the trackpad and mouse button to function as they should. In verbose mode its freeze in ACPI bad platform. The firmware restoration cd 1.4 not bot.
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Remove the hard drive and try starting from the DVD, "C" key. This should get it to run. OR Is this a new hard drive or an old bad one? If it's an old one you can try formatting using the "write zeros" option to map out its bad blocks and it might work.
Score 3
Comments:
Thank you for your response. I have tried almost everything: start with the DVD OSX.5, OSX.6, OSX.7, usb with LION, I changed hard drive, I put a hard drive of another MPB, I changed the battery, the keyboard, I unplugged the accessories (Bluetoth, wireless card), I changed my ram, I changed the hard drive connectors, I changed the dvd drive and still nothing. I wonder if this is not a problem with the heat detector. I'll try that.
by
Add a comment
my MC notebook cannot go beyond the white screen and it posses a question mark on the screen what can I do to solve this probem?
Comments:
Please start a new question as your solution may be very different. Thanks
by
Add a comment
Add your answer
saulvi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 397
