Early 2011 model, A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor.
608 Questions View all
Where are the water damage stickers located?
Hi I want to know where are all the water damage stickers located on the macbook pro 13in 2011 "MC700LL/A", and where can I get them.
thanks in advance.
Comments:
Apple MacBook Pro "Core i5" 2.3 13" Early 2011 Specs
Identifiers: Early 2011 13" - MC700LL/A - MacBookPro8,1 - A1278 - 2419*
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
We're really not here to help you cheat Apple into performing warranty work on a machine damaged due to your personal negligence. Please "man up" or go elsewhere. You can also talk to your insurance agent and see if you're covered or tell us what the machine is doing and we can try to help you repair it or direct you to someone who can.
http://dictionary.reference.com/browse/i...
Score 3
Add a comment
I don't think there is any water damage stickers, however, there is a water damage indicator (it will turn pink or red if water has entered the unit). It is located right underneath the track pad inside the unit.
Score 3
Add a comment
we won't help you cheat apple, but we'll help you try and fix it
Take it apart and remove the logicboard and heatsink, and soak the motherboard in isapropal alcohol for 24 hours while scrubbing the board gently with a toothbrush GENTLY to remove gook and oxidation, put the computer together and see what happens and use quality thermal paste on it(artic silver 5 or Cooler Master high performance), if that is no help, replace the top case
if that doesn't help, it will be much more costly to fix, and you should sell it to cut your losses for parts, and yes, I have bought used liquid damaged machines before, although i pay very little for them just in case due to the unpredictable nature of them and repairability of them, so don't expect much
Score 2
Comments:
Here's the guide for dealing with Electronic water damage: Electronics Water Damage
by
Add a comment
Add your answer
fabian micro will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 4,683
