Model A1288 / 8, 16, or 32 GB capacity
582 Questions View all
Can I upgrade a 2 generation touch to a 4.0 or higher?
Is it possible to upgrade to a 4.0 on a 2 generation touch iPod
Comments:
Samantha Green, I do believe that you are talking firmware here?
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
The max is 4.2.1 for this generation. It's not going to go any higher.
Yes, some apps like Angry Birds cause a problem. This is to do with the OpenGL support on 4.2.1, since it's simply too old to support the version of OpenGL that Angry Birds now requires to run.
You can try, but if it complains about OpenGL it won't install due to a OpenGL incompatibility. You'll need to get a newer iPod to run Angry Birds.
Score 3
Comments:
How do I upgrade? I upgraded to 3.1.1 but can't get anything else. I need it to get the new angry birds space game. It needs a 4.0 or higher
by
@Samantha Green, like nicksmacandpchelp says, 4.2.1 is the last update available for the 2nd Gen iPod Touch. You can try and download the firmware from here and install it the way that is described at the same website. Hope this helps, good luck.
by
Add a comment
Add your answer
Samantha Green will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 992
