Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
817 Questions View all
My screen was cracked, replaced, still wont work.
I replaced the screen and cover on my IPOD. I have checked the connections several times and everything looks the same as the guide. For some reason my IPOD will no longer turn on, even though it did before and I have charged the battery. It will not sync to my Itunes either. Any thoughts on what could be the problem?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Have you check connectors with a microscope?
Also, that type of issue seems to be when you replace the screen without first turn the device off. I have a similar issue before and after carefully look at the logic board connectors I found that one of the contact was broken, so I put a little bit of soldering work and fix the problem. Hope this will guide you.
Add a comment
Add your answer
eamanganaro will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 183
