Hewlett-Packard began manufacturing personal laptop computers in 1993.
1388 Questions View all
replacing cmos battery hp lap top
HP ProBook 4410s
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
barry till, you can follow these instructions:"
Before removing the RTC battery, follow these steps:
1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then unplugging the AC adapter from the computer.
4. Remove the battery.
5. Remove the following components:
a. Switch cover and keyboard (see Switch cover and keyboard on page 64)
b. Palm rest
c. Top cover on 14-in models
Remove the RTC battery:
1. Position the computer right-side up with the front toward you.
2. Remove the RTC battery from the socket on the system board.
Reverse this procedure to install the RTC battery.
Or you can download the maintenance and service guide from here. Hope this helps, good luck.
Score 2
Add a comment
Add your answer
barry till will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 33
All Time: 5,151
