Repair guides and disassembly information for the 14-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2442.
MacBook Pro 2021 refurbished battery is very old?
I recently bought a refurbished MacBook Pro 2021 14", and coconutBattery has the battery as being manufactured in early 2017 - is that likely to be a problem? Is it worth thinking about a replacement?
Edit: The battery is also consistently charging at a low wattage (around 24W at most) despite being plugged in with a 100W brick from Anker.
Add a comment
1 Answer
Chosen Solution
Sounds like someone did a half repair as the orginal battery failed from the over charging it was getting from the logic boards SMC logic which wasn’t fixed. If you bought this system from Apple I would get therm to repair it r just reverb it as this will requir deeper logic board repair skills.
Score 1
Add a comment
Add your answer
Dan Hill will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 59
