It is stuck on the white screen with the apple?
How do I reboot it or get it past the white screen with apple and turning white circle?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
First try booting in Safe mode by holding down the Shift key. If that works go to Applications - Utilities - Disk Utility and verify your disk. Repair if necessary. If this doesn't work:
Boot from your installation disk in the CD drive, Wait till the second of third page till the pull down menu appears then go to Utilities - Disk Utility and verify your disk. Repair if necessary.
If this fails reinstall the system. Still can't see the drive? ome back and we'll tell you how to replace your drive.
Score 2
Add a comment
Most Helpful Answer
Well a few troubleshooting steps from here would be the following
Safe Boot-hold down the shift key while booting, key must be held down till the gear shows up under the apple
Boot to the Install DvD and run repair disk (holding C down during boot)
-this is done in the utilities menu through disk utility
Reset the PRAM
-hold Command, Option, P and R during the boot process
As for rebooting the only way to do it from that screen is holding the power button till the unit powers off.
Score 2
Comments:
Good answer, you beat me by a minute +vote
by
Add a comment
It doesn't go to the safe mode when I press the shift key. Is there any other way?
Comments:
Both answers tell you to boot from your installation disk.
by
altddav777, that is why it is so much easier when you ask your own question. You could click on the link on the right side of this page "ask a question" and give as much detail as possible. That way, the experts will see that you are asking and not answering this question. Good Luck
by
Add a comment
Add your answer
Irene will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 31
All Time: 5,256
