Can I open a 2nd Generation iPod Shuffle to dry it out?
Is there a way to pull the ipod shuffle (2nd generation) apart in order to dry it out? This was due to it inadvertantly going thru a laundry cycle.
if that was helpful hit the answered button no ones does it anymore thanks.
ppl pop in for one thing and get there answer and forget about this site.
Add a comment
1 Answer
Chosen Solution
Of course you can you here iPod Shuffle 2nd Generation Teardown if it was mine personally I would use some rubbing alcohol and fine toothbrush to clean it up a bit and rinse it with distilled water ,shake it out let it dry , do not use a hair dryer to speed it up you can melt solder unless you have a no heat option , good luck.
Score 2
Add a comment
Add your answer
Mary Ann Benson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 757
