Mid 2006 / model number A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor.
513 Questions View all
Why MacBook backlight doesn't work?
How can i understand why my macbook backlight doesn't work? I can see something on the screen and when i turned it on or when i wake it up from the stop status, the dsplay works for a few seconds... However i can't find what's the reason... i have to fix the inverter, or the inverter cable, or the lcd...??? Sorry for my bad english... :)
Add a comment
1 Answer
Chosen Solution
If you can still see the desktop, your problem is most likely the inverter or inverter cable. Hook it up to an external monitor to verify the GPU. Move the screen up and down to test the inverter cable. Here's the fast guide on it: MacBook Core 2 Duo LCD & Inverter A1181 (fast method) Replacement
Here's the longer guide if you need to replace the cables: MacBook Core Duo Inverter Replacement
MacBook Core Duo Inverter Image
Guide
Difficulty:
Difficult
1 - 3 hours
MacBook Core 2 Duo Installing LCD & Inverter (fast method) A1181 Image
Guide
Difficulty:
Moderate
1 hour
Score 1
Comments:
I have yet connected an external monitor, so i know that the GPU works correctly... If i move the screen up and down doesn't change anything... so i can be sure that the problem is the inverter??
by
If you can still see the desktop, your problem is most likely the inverter or inverter cable. If it's black then it's most likely the LCD.
by
Add a comment
Add your answer
Davide will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,414
