Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1496 Questions View all
Front panel broken is lcd?
Front panel broken. Does not work when i tuoch the screen, but it is still active.
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
The LCD Display shows the images. If the images are perfect then your LCD is OK. If the front screen is cracked or the touch screen does not respond to the touch of your finger correctly, then this is the Digitizer. If you decide to replace the Digitizer you need a Front Screen and Digitizer for the iPhone 3G. (the 3GS part is different)
Add a comment
Add your answer
Monica will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 317
