Mid 2006 / model number A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor.
513 Questions View all
Why is the bottom casing coming off?
On the bottom of my Mac, there is a plastic/rubber sheet that is screwed into the main metal housing. One of the screws is missing, and when i got a new screw to put in, the rubber started peeling off of the edge and there seems to be more rubber than edge, and it doesn't all stay in. I don't want to go to the Apple store because its kind of far away, and i was wondering if i could just do it at home. Please help!
Score 1
Add a comment
1 Answer
Chosen Solution
Apple will replace this free or send you the part to do it yourself:
MacBook Bottom Case Replacement Program
Apple has determined that under certain circumstances the rubber surface on some MacBooks may separate from the bottom case of the system. MacBooks shipped between October 2009 and April 2011 may experience this issue.
Apple will replace the bottom case of any affected MacBook, free of charge, that exhibits the issue.
Bottom Case Replacement Process
You may choose from three options to get a replacement bottom case for your MacBook. In all cases, your MacBook serial number will be checked to verify that it is eligible for this program.
Assisted service
Visit an Apple Retail Store - Set up an appointment with a Genius.
http://www.apple.com/retail/storelist/
Visit an Apple Authorized Service Provider - Find one here: http://support.apple.com/kb/HT1434
Self service
Order a replacement bottom case kit online: https://supportform.apple.com/201105
You will receive a kit that includes a new bottom case, screws, a Phillips head screwdriver, and instructions for how to remove the current bottom case and install the new one.
If you feel comfortable with the self-service option, you can place your order via the web.
Note: If your MacBook does not exhibit any signs of this issue, no action is required on your part at this time.
Additional Information
If you believe you have paid for a repair or replacement due to this issue, contact Apple regarding a refund.
This worldwide Apple program does not extend the standard warranty coverage of the affected MacBook.
This program covers affected MacBooks for two years from original purchase date. Apple will continue to evaluate the service data and will provide further extensions to this program as needed.
Score 4
Comments:
I believe it was ordered around Christmas 2010, so I think it is ellegable. Thanks for the help!
by
I went to the link to order a new one, but when i enter the serial code, when i hit the button, and the button acts as if its been pressed but nothing happens.
by
Have you tried with Safari and/or Chrome?
With Firefox the Apple site may be finicky, especially if you've got some weird extensions.
In the worst hypotesis, you can always go through an AASP, bringing along the laptop, so they'll make the order for you.
by
Add a comment
Add your answer
Eli will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 144
All Time: 8,083
