2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
930 Questions View all
Can I just swap screens?
I have a dead A1226 and have a working A1260 screen. Can I just swap the screens and not have to take the back cover off, the bezel to just have a working MBP? Are they compatible I cannot tell by the pictures but they do have a different part number???? But the connections look the same. Thanks, Steve
Comments:
Worked like a charm. Thanks!
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Yes they have the same LVDS/video data cable, click here to verify that. They have the same inverter/iSight cable, click here to verify that. They have the same hinges, click here to verify that. Same bezel & rear display housing, click here to verify that. I could not find the lower case right off, but the same rear display housing says the hinge spacing is the same between the 2.
Yes you can do that.
Score 3
Comments:
Thanks I am taking them both apart now and will verify! Thanks a bunch. I basically did the same research but wanted to be backed up with another's verification!
by
Add a comment
Add your answer
Steve will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 601
