Repair guides for cell phones by manufacturer Nokia, including smartphones and a wide variety of the iconic "brick phones". This category is for phones not using an Android or Windows operating system.
463 Questions View all
Error : Please change the battery cover
From past few day my Nokia n91 mobile shows me a strange error when we access hard disk like - "Replace Battery Cover" and other error is "hard drive is unavailable" . can anyone help me how to solve this problem please?
Thanks in advance
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
"The common working solution to fix this dreaded problem, is to reset the mobile phone, this is easy for you to do. Simply power on the phone and enter the reset code which is:*#7370#. Once you have entered the reset code, it will ask you to enter a code which is: 12345. Once entered, the phone will reboot and will be reset to factory settings and should make the hard drive work. If the reset doesn't work, then update or reinstall the firmware on your Nokia n91 that is having hard disk problem, as there could be fault developed in the firmware that can stop the hard drive from working." from here. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
mike will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 671
