Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 Questions View all
Why no sound output?
I replaced the head jack on my ipod, made sure all of the wiring was correct, etc. I still have no sound output on my unit; the ipod shows it is playing the song but there is no sound. I tested my external speakers and they work when I plug them into my computer, but not my ipod. Any ideas?
Add a comment
Chosen Solution
yates, here is my answer from a question very similar to yours.
"There is the possibility that you need to exchange the headphone jack. Not a terribly difficult or expensive repair. Of course, first try to insert and reinsert your headphones a couple of times in a row, potentially loosening a stuck contact. should that not work, try to replace the jack. http://www.ifixit.com/iPod-Parts/iPod-Vi... is the part and the guide is here Installing iPod 5th Generation (Video) Headphone Jack & Hold Switch you can also try a restore with itunes, just make sure that all your data is backed up before you restore.
There is also another possibility, not as nice as the first one. In the case of your iPod I am leaning more toward this problem. This particular model has a problem with an IC on the logic board. You can try and see if you get sounds by applying some pressure to the right lower side of the ipod, almost between the click wheel and the bottom corner. If you should get sound by doing so, then you only have very few options. One is a new logic board for about $40 on eBay; the other one is to reflow your old logic board. Or you can try what warnergt did on http://forums.macnn.com/103/ipod-iphone-... By now I can verify that this works since I performed a reflow on three of the boards and it solved the problem. The logic board is of course available at ifixit as well." you may also try another headphone jack. You may have one that is not assembled correctly. :-) Hope this helps, good luck.
Score 1
Add a comment
this is probably your answer, mine has the same problem(or should say had because it is working today) https://discussions.apple.com/thread/109...
Add a comment
Add your answer
yates will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 47
All Time: 1,964
