The 4th generation Surface Laptop, released in April of 2021, shares the same body design as its predecessor, with upgraded internals including Intel 11th gen and AMD Ryzen 4000 processors, more RAM, and upgradeable SSD storage.
Overheating! Can’t install New Windows
The laptop is overheating whenever i try to install the windows, deleted the previous windows as it was corrupted. Now in order to make the laptop work i need to install new windows in it, but it keeps overheating and shutting down after a few minutes of installation. Is there anyway that i can stop that from happening?
And, if someone knows where can i get a new motherboard for it, please let me know. Thanks!
Add a comment
1 Answer
It might not be the motherboard. You might want to replace the thermal paste in the device. Follow this guide, and then install new thermal paste onto the die of the heatsink Microsoft Surface Laptop 4 (13.5-inch) Heatsink and Fan Replacement
Make sure not to strip any screws, as that could cause the heatsink to not have direct contact with the CPU. You will also want to be very carefull applying thermal paste, and make sure to cover the whole die, and not to scratch it.
Good luck fixing your device!
Add a comment
Add your answer
Syed Shoaib Ali will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 135
