Keeps reboot, returned error 9 during restore
Hello there
My apple tv suddenly not work properly. i just power off at the night and power on next day
when I power on apple TV, it looks start boot sequence.
but just after apple mark shows on screen, it reboot.
apple mark -> reboot -> apple mark -> reboot...
i tried restore it via iTunes using micro USB.
apple tv appears on iTunes. but not able to restore. iTunes returns error 9 every trial.
LED on apple TV keeps blinking 3 times every second. then more than 5 times blinking a second. it looks rebooting..
is there anyone having same issue or any solution?
looking for any help.
thanks
Update
thanks machead3
it looks apple tv2 accepts remote signal. i was able to enter DFU using remote..
anyways, mine is still not work. i tried almost every method i was able to find. all returns error 9.
i was for sure mine has s/w issue not h/w but it looks h/w fault. it keeps reboot during iTunes restore process then returns 9 error.
this product is not available in my country, so i was not able to get any support from apple. going to stats cost 20s of apple tv.
it's time to give up... good bye apple tv2. i was happy with you.
(but 10$ per month is too expensive. i thought you are my forever friend!)
my new friend, apple tv3 will be arrived by 15th May.. looking forward to meet it. don't betray me this time....
Comments:
thanks machead3
by
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
Completely disconnect the AppleTV from everything. Make sure iTunes is completely up to date. Plug only the USB cable. Try the restore again.
About the blinking Apple says:
  1. Flashes three times = Rejecting a command from the remote (you've paired a remote with Apple TV but you're using a remote that's not paired); see Apple TV: Pairing and unpairing the Apple Remote.
  2. Flashes quickly = Having issues. Your Apple TV may need to be reset and restored to factory settings. See Apple TV (2nd generation): Restoring your Apple TV. If this does not resolve the issue, refer to the Service FAQ for additional assistance.
If this Answer is helpful please remember to return and mark it Accepted.
Comments:
Are you connecting through a USB 1.1 port (instead of a USB 2.0 port)? If so, I think that may be the source of your problems.
by
Add a comment
Add your answer
bum will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 8
All Time: 2,609
