Apple's line of MacBook Pro laptops was intended for the professional and power users. The MacBook Pro line includes the MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17", and the MacBook Pro 17" Unibody.
14119 Questions View all
LCD has lines through it, but is not cracked.
Not sure why this would happen.
Any advice on what it could be?
I thought it was either the connecting cable or the inverter.
-Varsity
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
The LVDS cable is the video cable that carry the video signal from the logic board to the LCD panel via 2 connectors. Dark shadows can be caused by a defective backlight lamp if the shadows are starting at the screen base or by pressure points on the screen (applying excessive pressure in the screen with the fingers, etc). In the two cases the LCD panel must be replaced.
Concerning the varsityanchor lines issue, that's bad news if you get no video on the external monitor. Most of the time that leads to a defective logic board since the early MacBook Pros had problems with the Nvidia 8600 and the Ati 1600 GPUs. But you should get an image on the external if you have one (even with lines) on the internal. Are you sure the external monitor is well connected ?
Add a comment
Most Helpful Answer
Lines can be a result of either a defective LCD panel, LVDS cable, or Logic board.
you can test the MacBook Pro with an external display to rule out Logic board.. next step would be to make sure the LVDS cable is not loose, or damaged.. if all looks good.. perhaps test with a new LVDS cable. LCD is usually the last thing to go wrong. but some people are foolish enough to grab the notebook by the display.. pressure on the panel and damage the circuitry.
Score 1
Comments:
The MacBook Pro does work with an external display. Could it be the inverter or the display cable?
by
The "display cable" is called an LVDS Cable.. it is absolutely not the inverter or inverter cable -
by
Add a comment
What is the LVDS cable?
i have some defect, apple says that need to replace display, i dont believe! I have some dark shadows coming from the bottom of the screen upper. Everything works well, except this inconvenience.
I will test with an external display to rule out the logic board, but what is the LVDS cables?
thankx
MacMiguel
Add a comment
Thankx for the explanation, yours was the most clear one, the Apple guys never told a clue just saying that i must replace the Display without any detail about why.
So i can survive with the computer as it is, meanwhile i will plan what i will do in the future, buy a new LCD and replace myself, or buy a used MacBook Pro as mine and replace the complete display, or buy a new computer and sell mine for spare parts ...
thankx once more for the help
MacMiguel
Add a comment
Add your answer
varsityanchor will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 32
Past 30 Days: 131
All Time: 17,062
