2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
MBP Beeps Every 5 Seconds No Boot Up
MBP suddenly shut off last week and will not boot back up. Every time I plug in the magsafe charger, or push the power button with charger unplugged, I begin to get a beep every 5 seconds from inside the machine. Have tried SMC reset and all combinations of keystrokes and power button. Screen is black, fan doesn’t start. Opened up the bottom cover and everything looked okay without digging into it, just dusty. The beeps seem to indicate a RAM issue according to searches about other models, but I believe this model cannot have the RAM repaired as it is soldered to the board. I need to get some data off of this machine that was not backed up! Oh no! Please help!
2 Comments
Hey guys - both of these sound like great ideas. This is an 11 yo machine so I’m not super worried about bringing it fully back to life (tho I love it so). I just got a M2 MBA yesterday, and would love to transfer what wasn’t backed up to this new machine. Sounds like both Dan and diss are suggesting options that involve me removing the ssd and installing it into this envoy which seems doable (and cheap). Do I need to do the full solution with the OS installing if I just put the ssd into the envoy and plug that into the new machine? Any videos you can refer me to of course a huge help.
And THANK YOU for your timely responses and details thus far. Was of course told I was dead in the water by all of the AASP’s and Apple themselves.
by
@max52484 - No need to reinstall the OS as your not running the external drive (using the Envoy case to hold your SSD)
As your now running, I would backup your stuff or use Target Disk Mode to transfer your stuff to your new system.
by
Add a comment
Chosen Solution
Alrighty. You should have a removable SSD (Solid State Drive) and you can find out how to remove it here: MacBook Pro 13" Retina Display Late 2012 SSD Replacement
EDIT: Order a NEW logic board and replace it, please look at the iFixit guide for help.
You should buy a SSD to USB 3.0 to plug into another computer and copy your files. After you made sure the backup is secure, put the SSD back in. After that process, install macOS onto a blank USB (I recommend a 32 GB USB) and hold down the option key. You should see an option with a USB icon. Click the USB drive and then hit the arrow. If you get to the installation screen and it does not give you an option to install off of the SSD, go into Disk Utility and erase the SSD. Double check you have your files copied to your other PC. For the new drive name, I would choose "Macintosh HD". It should install, but make sure you keep the USB drive into your MBP until you are sure the setup is fully finished! (being able to go onto the desktop screen, and you can see your finder icons.)
After you get macOS installed, take the USB out and format the USB with the PC you copied your files with. Then, drag all of the files onto the USB in the file viewer (could be Finder or Explorer) and wait for them to fully copy. Safely eject them by finding the eject icon (⏏) and plug them into your MBP. Copy the files to your MBP and keep the USB drive in a safe place for a backup.
I really hope this helps!!
Score 2
2 Comments:
I opened it up, got to step 8 on the linked guide above, gave the entire machine a solid brushing with a soft brush, inspected each RAM chip for damage, hair, dust, debris - and before I went further I tried the power button just to see what would happen… fans started spinning. No beeps… so I put it all back together and plugged in the charger and eureka! Back in business! Thank you everyone!
by
No problem! I am happy to help :)
by
Add a comment
Well you are in a bit of a pickle! Sadly, the beep code is telling you the RAM has a failure, and the RAM is soldered to the logic board. You might be able to find someone with the needed skills and tools to replace the bad RAM chip/s.
The other direction is taking the blade SSD out and using an external drive case like OWC Envoy Pro
Then you can transfer your stuff over to another Mac.
Score 1
Add a comment
Add your answer
Max will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 8
All Time: 108
