Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1497 Questions View all
Why my touch at the bottom level is not working?
My iphone's touch at the bottom lineup is not working.
I mean, the bottom level..Else is workin fine.. Even i can slide when cal is coming.
But cant click on the "Answer" or "Decline" buttons.
help please/
I did restore, bt not working..
Help
Comments:
Same here But im not confident to take off the screen as i might damage my phone more
by
Hollzkid, you may have to get it fixed by one of the numerous phone repair centers;-)
by
Add a comment
Chosen Solution
sam, it is my experience that if a certain region of the digitizer (touch screen) does not work, it needs to be replaced to be fixed. This is due to broken contacts within the digitizer. Here are some directions that you might find helpful, good luck.
Score 1
Add a comment
Hi Sam,
By the sound of it, the digitizer cable may have become dislodged from its connector on the board. My suggestion is, if you are confident to do so, pop the screen up on your phone, and gently push on connector number 2 to push it back into place, try using this video guide to get your screen off, all you'll need is a Phillips cross-head screwdriver, and a small suction cup. Hopefully this should solve your problem, and have your phone fully operational again.
Add a comment
hey, I have the same problem, only that that part actually works if I flip the screen in landscape mode, and certain apps like music player get the touch commands, even if laggy. Restoring didn't work. What do yau think?
Add a comment
Use an android app to fix that
Add a comment
Add your answer
sam will be eternally grateful.
Past 24 Hours: 35
Past 7 Days: 260
Past 30 Days: 932
All Time: 35,170
