The Xiaomi Redmi Note 8 is a mid-range smartphone by Xiaomi released October 2019. It has a 6.3" IPS LCD display, a 48 MP main camera, a rear-mounted fingerprint sensor, a 4000 mAh battery, and runs on a Snapdragon 665.
Why my phone stared turning on and off even may battery is 50%?
My Redmi Note 8 is starting to turn on and off, what do I need to do?
Add a comment
1 Answer
Most Helpful Answer
Hi @joshuamatias,
Does it also do this when the charger is connected?
Things to try that may resolve the problem:
  • Wipe the cache partition and check.
  • Try using the phone in safe mode and check if it works OK. If it works OK when in safe mode, then a downloaded app may be the problem. The trick is to find out which one. You will need to uninstall each downloaded app, one by one and test the phone in normal mode between each uninstall, to see whether it worked OK or not. When it does then the last downloaded app the was uninstalled was the culprit. A downloaded app is one that you downloaded and installed and was pre-installed on the phone when you got it.
Score 1
Add a comment
Add your answer
Joshua Matias will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 79
