Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
Water Damaged Machine, Causes Random Reboots.
My macbook pro (has water damage) and randomly shuts itself down or re-boots about once an hour or sometimes refuses to charge or power on i have tried resetting the SMC and other common things to no avail
im just guessing there is some corrision to the logic board is it possible i could go and buy some de-oxidation solution or something and clean the contacts on the board could this help or hurt the machine more
Add a comment
1 Answer
Chosen Solution
You can't hurt it much more, unless you damage a connector or part with vigorous cleaning. (Nothing ventured-nothing gained). After reading about "water damage" or "liquid damage" on this site, purchasing the proper tools & some thermal paste, follow the teardown and clean both sides of the logic board... reassemble. It may work. If not you've had practice removing the logic board so you can install a replacement if you determine it cost effective.
Good Luck,
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
1 Comment:
+ Click here and select the "logic board replacement" guide for instructions on it's removal. Click here for the iFixit generic liquid damage guide, for instructions on how to clean the board. As Machead3 mentioned do not forget to apply a very thin, even layer of thermal compound to the CPU & video chips prior to reassembly.
by
Add a comment
Add your answer
James will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,514
