Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1496 Questions View all
Removing Cables in wrong order?
A broken 3g was recently given to me that was fully taken apart and i dont know whether they removed the cables in the right order or not? What should i do if i want to repair it as far as reconnecting the cables?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Provided none of the cables are broken, it shouldn't matter what order they were taken apart in. If they still have all the the numbers on the foam, you can kind of follow that order to put it back together. Here's a guide for taking the iPhone apart to the rear panel- that's the most comprehensive guide I know of. Just work backwards. :)
Add a comment
Add your answer
juan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 732
