Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1957 Questions View all
Phone will not turn on with battery, OK with cord.
I replaced the battery in my 3GS and the process was simple. My phone operates perfectly when plugged in. When the power cord is removed it shuts off. The battery charged OK as I watched the green indicator slowly progress. Any thoughts on what I missed?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
John, since your phone works without any issue while connected to an auxiliary power source, recheck your battery connections. It does look like you might have a bad battery. This is not uncommon. Speak with the vendor where you got it from and replace it once more. A battery may appear to charge, but not actually holding a charge.
Score 1
Add a comment
Add your answer
john will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 488
