Screen replacement gone wrong, need some advice on what to do now.
I am currently fixing a cracked screen for a friend, but this has not gone at all how I wanted it to. So during disassembly I accidentally tore the power cable slightly, which in turn mess up the volume buttons. I have searched high and low and can't find a guide on exactly what to do to fix that, although I know it requires soldering (which I have no experience with). I really need help here because I want to know if it is best just going forward with the screen repair, or if I should take the time to try and fix these buttons? In addition, I needed to order a new screen because the old on cracked when I was trying to install it. Reason: it did not lay uniformly and I applied a little too much pressure. Thanks to everyone to gives input
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Ripping the volume/lock ribbon is a very common issue to run into on your first go round. I am not aware of any guides for that but it is kind of a pain, especially if you have never taken an iPod apart. You have to unsolder the 4 points that connect the ribbon to the board (there is a good picture on the teardown guide on step 10).
The proper way to do it is to remove the logic board because the ribbon runs under a part of it. You can get away with running in under the board but it is not easy. If you look at the teardown guide until step 15 it shows you how to take everything out. The tricky part for some novice solderers is reattaching it because you have to make sure you have 4 separate solder points, none of them can be touching or else you will have a problem.
IMO I do not think it is worth the time,
Make sure you have the metal clip attached to the screen over the ambient light sensor (hold the screen up to the light and you will see the dot). Then when you are ready to seal her up push in the digitizer ribbon so it folds on itself and rather than pushing the screen straight down try to hook in the metal bracket in sort of sliding motion. If you mess it up and want to try and reset it just heat it up and you will be able to remove the screen without damaging the LCD. Hope that helps and let me know if you need any clarification
Score 1
Comments:
Alright, I will attempt the screen fix again and forget about the buttons. I don't really want to mess it up more than it already is. Thanks, will report back!
by
Add a comment
Check these out. I would advise that you find someone who's an experienced solderer (with the right micro tip) to do this.
How should I install the on/off/sleep & volume flex cable?
http://www.youtube.com/watch?v=QS0OmORQF...
You can buy a new flex cable for this job cheap on ebay.
Add a comment
Add your answer
David A will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,502
