Repair documentation and service information for Hisense televisions.
Interruption during firmware update, can this be fixed?
I went to update my firmware on my TV with usb and I guess it was interrupted during reboot. Model number is 55H6570G.
When it's on, the red light constantly blinks I can tell the screen is lit up but it's blank. Nothing I do is working unplugging it for minutes or hours at a time hasn't worked. pressing input and volume down button hasn't worked. Is there anything I can do to fix this? There isn't a reset button and the red light just consistently blinks.
Add a comment
1 Answer
@teajay65092 all those errors you are listing happened after you tried an update. I suggest that you try it again and see if that works. The EEPROM for that is on the mainboard and of course, there is not data available about it. If you can't fix the failed update, you most likely will need a new mainboard.
Add a comment
Add your answer
TeaJay will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 299
