Apple's top-of-the-line smartphone for 2020. Announced on October 13th and released November 13th, the iPhone 12 Pro Max sports a 6.7" OLED display, a triple rear camera system with LiDAR, and 5G connectivity. Successor to the iPhone 11 Pro Max.
108 Questions View all
Why does my BMS board get extremely hot when trying to spot weld?
So I have done this before and it worked perfectly on an Iphone XS. But I tried to do it on an Iphone 12 pro max and something really weird happened. I cut off the BMS board from the old battery and I had ordered a new battery with nickel tab on it for spot welding. Everything looks fine and then I wanted to begin spot welding but as soon as I arranged the battery and the bms board in the right direction so I could spot weld my BMS board was super hot in an instant. I quickly seperated it from each other. I couldnt see what I did wrong as I've once done it and nothing happened. So I tried it again. Place the battery and then align the bms board on to the nickel tabs so I could spot weld and again it immediately got super hot. Someone else who has had this issue? Can't understand what I did wrong
1 Comment
Incorrect polarity?
by
Add a comment
1 Answer
Most Helpful Answer
As F Dryer says, it sounds like you have the terminals the wrong way round. Either that or the bms was damaged when you removed it.
Score 1
Add a comment
Add your answer
Rahman Chinxo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 37
