Released on September 24th 2021, the iPhone 13 mini is a smaller version of Apple's iPhone 13 and is the second mini iPhone. It features a 5.4-inch OLED, an A15 Bionic processor, and dual rear cameras.
31 Questions View all
13 Mini restarting randomly SMC PANIC - ASSERTION FAILED - BSC failure
Hi,
my iPhone 13 Mini crashes and restarts every 3 minutes. Error log shows SMC BSC failure of type 0x1000 , which should be the proximity flex cable. However, after disconnecting it, the error continued to exist. Is this possible? Should I still change the proximity flex cable altough disconnecting it didn't result in a fix?
Score 1
Add a comment
1 Answer
Chosen Solution
Disconnecting it doesn’t resolve the issue. You’ll need to connect a known good to get the error to clear. The issue is that it’s not getting communications from a sensor on this cable. Disconnecting it will continue to produce this error since the sensor is still not present. It needs a good sensor that can communicate properly with the CPU to be connected.
Score 3
1 Comment:
thanks! I will try that and report my results asap.
by
Add a comment
Add your answer
Zhi-Yuan will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 80
All Time: 678
