Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
No service after a small "repair", what gives?
I put my iPhone 3G back together after removing the power button, I removed it because it was damaged and then I used led to act as a solder to keep the phone in an 'ON' position. Only problem is that now, the phone says No Service always. Did I ruin something?
Also, I have Wifi so does that mean the antenna isn't damaged?
Score 1
Add a comment
Most Helpful Answer
You might have messed up the SIM card assembly, try removing the SIM card, cleaning it's contacts, and reinserting it.
Score 1
Add a comment
The WIFI antenna is in the upper part of the phone - the Cellular antenna is at the back of the dock connector assembly! They have nothing to do with each other.
I found a great tutorial on the net. Maybe it will help you!
"How I recovered my iPhone's lost GSM signal!"
http://www.mauron.net/iphonerepair/
Add a comment
Add your answer
henry will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 6,822
