All-in-one 3210 has print error Oxc18a0401, what does it mean EXACTLY?
Have replaced ink cartridges with HP02XL and still will not print. Have followed HP's proceedures with no luck. Any ideas?
Cancel
Repair guides and support for the line of photo inkjet printers by HP.
Rep: 1
Chuck, have you tried this yet:
"Solution 1:
Press and hold the "*" key. Press the "#" key and release both keys. Display should say "Enter Special Key Combo"
Press and release in sequence the "1", "2" and "3" buttons. Display should say "Support" and display the FW rev (something like R0631R).
Press and release the right arrow button until the display says "System Configuration Menu".
Press and release the "OK" button. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
Press and release the "OK" button. Display should say "Hardware failure status: Clear. Press OK to clear".
Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
Press and release the "CANCEL" button as many times as necessary, until the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. Do not try to print at this stage.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
Turn the unit on. The printer may display message "Use Power button to shutdown the printer" followed by "Press OK to continue".
Press OK. The Printer will start the "One time ink initialization process". Allow this process to complete and do not interrupt.
Once the initialization process is complete, the printer will print out a Diagnostic Page." Great information with more solutions from here. Of course I almost forgot, Error 0xc18a0401 Ink System Failure. Check on here for more infoas well. Hope this helps, good luck.
Rep: 1
Rep: 1
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 48
All Time: 2,001
We have a chance to guarantee our right to repair electronic equipment—like smartphones, computers, and even farm equipment. This is a once-in-a-generation chance to protect local repair jobs—the corner mom-and-pop repair shops that keep getting squeezed out by manufacturers.
Join the cause and tell your state representative to support Right to Repair. Tell them you believe repair should be fair, affordable, and accessible. Stand up for your right to repair!
