Model No. A1367 / 8, 16, 32, or 64 GB capacity
1277 Questions View all
How do I turn off the Genius Playlist?
The following error message occurs every time a song is selected:
Try Again
This song does not have enough related songs to create a Genius Playlist.
The choice is OK.
Select OK.
Nothing happens
Try another song. The same error message.
Net result: No songs played!
Can anyone help me!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
zumbasunray, here is what Apple says about this "Sometimes if you sync a portion of your iTunes library to iPod or iPhone, you may be unable to create a Genius playlist with certain songs while using your device. You may see one of the following messages:
"This song does not have enough related songs to create a Genius Playlist."
"Genius is unavailable for the selected song."
If this happens, try making a Genius playlist with those songs on your computer. If you can make a Genius playlist in iTunes on your computer, then it is likely that there are not enough songs on your iPod or iPhone that go great with the desired songs. Try syncing more of your iTunes library with your device. If you are still unable to make Genius playlists from those songs, consider making Genius playlists in iTunes first, then syncing them to your iPod or iPhone." If you want to turn off the Genius features, go to the Store menu in iTunes and choose "Turn off Genius." If you want to get it back, you’ll need to turn Genius on again. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
zumbasunray will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 1,510
