The MacBook family was first introduced in May 2006 and replaced the iBook as Apple's consumer laptop.
3825 Questions View all
How to replace textile dust protector on optical drive opening?
I have a MacBook with a mangled dust protector textile bit on the optical drive opening (see pic).
I also have a spare bottom case, which I could take it off of, if only I could figure it out.
It's between the bottom case plastic and the metal bracket on the inside of the optical drive opening.
The metal bracket won't budge even with all screws removed. I'm missing something, any ideas?
Comments:
Thanks torontomac!
That was it.
Advice to people attempting the same: there's a lot of glue so use the force. ;) Also the dust protector itself is easily damaged, so be careful. Pry from under the metal bracket, not where the dust protector is.
by
benyusz Please change this to a Comment or Update to your Question. Only Answers belong here.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
its glued down
just pry it off dont be shy
and use the screws when you reattach
its more than enough to keep it in place
Score 2
Add a comment
Add your answer
Sandor Benko will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 493
