Repair guides for the MacBook.
3786 Questions View all
Question Closed
How to replace textile dust protector on optical drive opening?
I have a MacBook with a mangled dust protector textile bit on the optical drive opening (see pic).
I also have a spare bottom case, which I could take it off of, if only I could figure it out.
It's between the bottom case plastic and the metal bracket on the inside of the optical drive opening.
The metal bracket won't budge even with all screws removed. I'm missing something, any ideas?
2 Comments
Thanks torontomac!
That was it.
Advice to people attempting the same: there's a lot of glue so use the force. ;) Also the dust protector itself is easily damaged, so be careful. Pry from under the metal bracket, not where the dust protector is.
by
benyusz Please change this to a Comment or Update to your Question. Only Answers belong here.
by
Add a comment
1 Answer
Chosen Solution
its glued down
just pry it off dont be shy
and use the screws when you reattach
its more than enough to keep it in place
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 502
