Hot water kettle with digital temperature control.
The switch for temperature units is broken and doesn't go from F to C
Same as title. Switch gives no feedback. Can't go back to Celsius. I have tried unplugging and plugging back in but to no avail!
Score 2
Add a comment
1 Answer
Most Helpful Answer
I bought a broken unit that pleasantly came with an extra kettle, which presumably works.
I want to use the part from the bought but tattered unit to replace the part in the original base, but am trying to figure out how to pry the base open. I'm waiting to hear from someone who did successfully to figure out how to do it.
It's stuck on F because there's a board with a button that goes to C when the button is covered. You have a bad board/button and need a new one. I'll let you know how this goes as I make progress. I also took pics of the part board to show you what's going on and how it looks from the inside.
The switch is a Kailh switch, which is a cheap Chinese part that's made to break. This is just poor part quality.
Score 2
1 Comment:
did you ever figure out how to prise the base apart?
by
Add a comment
Add your answer
Ian Zeringue will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 19
All Time: 696
