Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
57 Questions View all
Orientation of on/off switch, button and cable
I'm working on an iPad 2 that was dropped. The drop requires the replacement of the volume control, on/off ribbon cable.
I've got most of the ribbon cable installed but am stuck at the on/off switch and need to know the correct orientation of the metal switch plate and button.
I have the button installed on the plate correctly but am not sure if the ribbon feeds from the top or bottom. Also, the button can go in two different ways-the metal piece on the back of the button has a plastic stop. Should it stop the metal piece from hitting the bottom or top of the case.
Thanks,
Ed
Add a comment
1 Answer
Chosen Solution
I just replaced the back and digitizer to an ipad 2, here is the best picture I took of the ribbon. Hope this helps (if it isnt too late!)
Score 1
Add a comment
Add your answer
dredison will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,253
