Apple's line of PowerBook laptops was intended for the professional and power users. The PowerBook line includes the PowerBook 100, Duo, 500, and 5300 Series; the PowerBook 1400, 2400, 3400; the PowerBook G3, G4 Titanium, and G4 Aluminum.
1282 Questions View all
Why is my Pismo's display dim?
I have two project Pismo's that I recently brought to working condition. One of the two has a somewhat dimmer (less bright) display than the other, even though the brightness is turned up all the way on both machines. Both have 500MHz processors.
Is the florescent backlight just getting old and worn out? Or, could it be another issue (the inverter)?
Add a comment
1 Answer
Chosen Solution
If the inverter goes you will barely be able to see the screen. The dimmer one may just be dealing with old age and starting to dim.
Score 3
Thanks Mayer, That was my gut feeling. I had not noticed something like this before. Two identical machines sitting side by side can really give you some perspective.
Add a comment
Add your answer
randy3833 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 362
