Why,no sound on calls but speaker works?
Changed Battery, all works exept the no sound on calls but if i press Speaker it is Ok,Sound on other apps Ok.
you need to check connector no.3 is in properly, it can be a little tricky. push the flex in until you meet resistance, not up to the white line it will be about 1mm from the connection, then push the lock down.
Hi Pollytinto,i didn`t realise that it slid into the connector(3) thank you so much. It is very difficult to connect and should be the first when replacing Screen assy. Thankyou Ted.S
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,829
