I want to repair the power suply on the above printer...
Can you guide me in as to how to access to the power supply for the Brother HP-2170 W printer please?.
Thanks
Thanks
Consumer grade printers aren't exactly easy to service, and they are generally more expensive to repair then the cost of replacing the whole printer. While you can probably find the repair parts, they tend to be expensive. The cost of OEM drums leads to people dumping these printers over consumables, so my advice is to get one of these printers and reuse your current drum and toner (reset the drum counter if you need to, but see my warning in the caveats listed). Depending on the life of the toner the printer came with, you may even have extra toner on hand. The drum may still be usable as well, but many of these printers are so close to 0% remaining it isn't worth trying to salvage this. It's your call what you do with the drum it came with depending on the remaining percentage.
However, this does come with a few major caveats:
If you do choose to repair the printer, you will need to see if it's a bad power supply or HV PCB, as these are likely to be the problem. More then likely it's a power supply fault, but you should also inspect the High Voltage PCB just to be sure. If it's a fault that is obvious, then it may be worth attempting the repair. If it's difficult or expensive I'd just recommend getting one of the many printers with consumed drums and then moving your drum and toner set to the newly acquired printer. You can get any printer that uses the same drum or another HL-2170. Of course, the old printer should be recycled or given to someone who can make use of the remaining parts. You can find the service manual here.
If you don't have a need to maintain compatibility with your old drum and toner find a printer that meets your needs that is on sale. Since the odds of the old toner and drum being compatible are low, I wouldn't look for this specifically.
+Solid performance in answering this one.
didn't answer question
Technically it does. The OP asked what to do and I recommended looking for a used one that needs an imaging drum and then moving the drum and toner they use over to the new printer (with the caveat of an inaccurate drum life counter, since there's now a known discrepancy). I also told them what usually fails so they can locate the parts.
It may not be what someone looking for a solution on this site expects since repair is encouraged, but it is a practical solution and my recommendation to get a used printer that uses the same drum and toner instead of the repair. It also keeps a printer that would otherwise be discarded over the cost of the imaging drum in use. You can check Craigslist or eBay for a low mileage printer that just needs an imaging drum or you can spend several hours (if not days) fixing a printer that's probably just about worn out.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 14
All Time: 7,277
2 Comments
i want to chang my brother printer mfc j220 head
pls help me wear i do it
by Sudhir Dhyani
Please help me. My brother printer MFC7340 is not turning on since I put it in higher voltage/wrong , instead of 110-120 volts only I accidentally put it in 220 volts. How much the repair will cost?
by Ma. Eliza Bagguatan
