Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
282 Questions View all
Where are the power pads?
Any chance you can upload the picture again? I need to jump start because seems like the power button is broken. Thanks.
Update
Not sure is the same motherboard. I have a a1286 model, it's actually a mid 2009 MCP. here's the pic of the logic board.
Update
I'm not sure if the image uploaded successfully on iFixit, but found your email and want to make sure you get it.
My assumption is that based on my picture, once I remove the Keyboard ribbon I would count 5, from TOP down on my PIC and short with ground on the logic board.
Let me know if this accurate, I hope this will turn it back on, if it does, all I need to do is buy the keyboard as this is the one that powers on the laptop.
Thanks,
Audel
Update
This did the trick for me, I was able to power on the Macbook. Now I will only need to order the keyboard as this is not working properly and also holds the power button.
Thanks Oldturkey!!!!
Score 1
Comments:
See if that is what you are looking for.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
A B the only thing I find in that service manual is this "-If no power, use conductive tool to short pin 5 of keyboard connector with ground on logic board as seen on image to the left. (Make sure you don’t touch any other pins on the connector.)"
Score 5
Comments:
Thank you for accepting my answer. Hope it will work out, all the best to you...
by
Add a comment
Add your answer
A B will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 34
All Time: 6,420
