Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
Question Closed
How cold is too cold?
So I live in alaska and I accedentally left my Mac in my car in the winter (-10 degrees). :/ I know its not good for it, but im wondering how cold is too cold?
Add a comment
1 Answer
Chosen Solution
Some of the capacitors and the LCD have liquids in them that can freeze at very low temps.
The real issue is trying to use your system at such temps. The hard disk platters shrink when they are chilled (Aluminum) so tracking, data reads & writes can encounter problems. If you do write any data on the disks you could encounter a non-readable disk when you try accessing it after it has warmed.
Lastly, if you don't let the system warm up carefully in a warm building condensation can build up inside.
Best to allow your system a good three-four hours or more to warm up sealed in a plastic bag before entering inside.
Score 3
1 Comment:
Thanks Dan that makes sense, I will try not to leave it in the cold.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 4,997
