won't spin; makes pulsating sound and room lights flicker
Everything works fine expect the spin cycle. As soon as the timer clicks into the spin portion of the rinse cycle (about half way through the rinse cycle), the machine pulses and thumps --at first I thought the clothes were off balance. The lights in the room blink in rhythm with the pulsing. I moved the dial ahead to the spin cycle, and the same thing happens there. It appears that the drum is jerking slightly, as well. Any help would be appreciated.
1 Comment
margie, before we find a solution, here is a quick thought. The room lights flicker because your washer is drawing a large amount of power. It will eventually pop your circuit breaker. I would unplug it or at least not use the spin cycle.
by oldturkey03
