The Canon Powershot A590 IS is an 8 megapixel digital point-and-shoot camera with a 4x optical zoom and a 2.5 inch LCD screen.
23 Questions View all
Where to purchase flash logic board for Powershot A590IS?
The flash no longer works. I tried setting back to factory default. Reading manual and online information to fix this problem. I was told by a technician who repairs the Canon PowerShot A590IS that it needs to have the flash circuit board replaced. I can repair this myself but cannot find where to purchase one. I have looked at canon, amazon, ebay, etc. with no luck. Where can this flash logic board be purchased.
Thank you.
Darlene
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Before you do anything, look at the price of a working camera that works before attempting the repair. Very often, you can get a nice used camera for the price of parts, especially for something this old. If the price of the repair is that much cheaper then replacement, then you can repair the camera if you decide to repair it rather then replace it.
There is going to be a lot of desoldering in this repair, so you will probably want to have a good soldering iron. It's probably also a good idea to practice soldering on junk first as well.
The best way to get parts is to find a camera with a good flash but has a lens error (this will show up as E18 on some older models) or a broken LCD, or maybe even a bad CCD. You're going to find parts are very difficult to find unless you buy a parts camera. I would suggest broken LCD or CCD so you can reliably test the flash with a few test pictures without a memory card. Your concern is the flash; not the lens, LCD or CCD.
If you are still having issues, it's either the parts donor camera had a bad flash or the board was bad. If it's the board and you know the flash is good, transfer the board from the parts camera to the old camera and move the back panel so the serial number is correct.
Here is the guide: Canon PowerShot A590 IS Flash Assembly Replacement
Score 1
Comments:
I agree with Nick, buy a camera that is broken from eBay for a few $ to get the flash board.
by
Add a comment
Add your answer
Darlene will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,430
