Model A1213 / 8, 16, or 32 GB capacity
216 Questions View all
iPod won't hold a charge even AFTER replacing battery
After 2 years, my iPod stopped holding a charge. I would plug it in and after a couple seconds i would get the red battery icon saying the battery was low,but with the plug over it indicating that charging was complete. Sometimes it would show it was charging and the indicator would go green, so I would leave it. But when I came back to it the battery had drained instead. I just replaced the battery on it figuring that it was the culprit and was ecstatic when it charged right up, but after I synched it it was back to it's old shenanigans. Any ideas?
Score 2
Add a comment
Most Helpful Answer
The batteries in most iPods have a ground strap that grounds the battery to the iPod's case. If you don't install this or do it incorrectly, the battery will not retain a charge
Score 1
2 Comments:
Did you mean "will *not* retain a charge"?
by
yes, sorry
by
Add a comment
I don't know about a ground strap. It had a ground wire that soldered into te board along with the pos and neg. I figured the connector might be the problem.
Add a comment
Add your answer
hennemonger will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,409
