Released in April 2020, identified by model number 26699-989-999-01
My Headband broke, now it flexes way too much
Hello Dear People,
I think I dropped my Evolve2 Headset, since then my headband flexes at the spot where the silicone patting and the plastics of the headband merge.
I want to take it apart but I´m a bit insecure about how to do this.
Has anyone any experience?
6 Comments:
@lukaslobuescher some of the "headbands" really can't be completely disassembled. It might help if you post some good pictures of what you got going on there, with your QUESTION. That way we can see what you see. Adding images to an existing question - iFixit Repair Guide
by
Hello oldturkey,
thank you for the answer!
I thought I already did upload the pictures...
Here they are
by
Yes, mine did the same. I designed and printed a 3D reinforcement cover. Seems to work well on both sides.
by
I have the same issue. I was googling for a while and found no take apart diagrams. Additionally, I couldn't even find any headband replacement as service part (there is always the option to look for broken ones and cannibalize it, but that will give a less working span for the headset...).
Is there any update on this topic?
by
same issue here. Anyone brave enough o open and try to fix it?
by
Show 1 more comment
Add a comment
1 Answer
I have the same issues. I ended up using clear tape on mine. I just ordered the a new pair. The Evolve2 65 Flex. They must knew about the issue because they built it different this time.
Add a comment
Add your answer
Lukas Lobüscher will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 68
All Time: 713
