Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3236 Questions View all
iPhone4 broke home button connector. any fix for this?
iPhone 4 Home Button Replacement
On Step 31, I broke the connector. After I did, I saw you could expand the page and there are notes. Several ohter people had the same problem. What do I do?
Add a comment
1 Answer
Chosen Solution
if it is only the black flip catch then see if the phone works with just the flex installed..you never know your luck! Otherwise you will need to purchase the dock connector which has that connector on it.
Score 1
Comments:
thank you! should i tape it down?
by
it should stay in without tape. the catch provides pressure to push the flex onto the pins, i've had these type of connections work well without tape or the catch. try it and see.
by
Add a comment
Add your answer
jeanne will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 5
All Time: 2,581
