Cardo Systems motorcycle bluetooth headsets: Packtalk, Smartpack, Packtalk Bold and Packtalk Black
Replacement USB connector P/N on PCB?
As with many other users I have a Packtalk Bold out of warranty with a bad USB connector. It works if the cable is held pressed up or down. Many have had solder failures but not this one, I need a new connector but studying images and footprints at Mouser and DigiKey has failed to ID a likely candidate.
Score 2
6 Comments
Did anybody ever find a solution to this problem
by
The YouTube link shows someone doing it, not someone willing to share the P/N.
by
Meh. My question is, “what is the part number of the usb socket?” The YouTube video and poster refuses to share his secret.
by
Show 1 more comment
Add a comment
Chosen Solution
you can find the correct USB connector here....warning...its a bit tricky without the right equipment. I have successfully fixed two so far with USB replacements. If the trace has pulled away from the board....you may need to fix that also. https://www.amazon.com/gp/product/B00NQB...
Score 1
1 Comment:
Thank you I bought a couple of these off Amazon from your link from uxcell and had my local “iKrack” micro solder shop replace one for me. It worked well.
by
Add a comment
Most Helpful Answer
is standard micro usb, but many Times on this model is the PCB lines missing, then need make jumper.
Score 2
Add a comment
There is a good Youtube video on this process: https://www.youtube.com/watch?v=FLr-Keiv...
Add a comment
Add your answer
David kelly will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 64
All Time: 980
