7th generation of Motorola's Moto G line. This phone was released in March 2019 and is the first Motorola Moto to use the Android 9 operating system. Model numbers are XT1962-1, XT1962-4, and XT1962-5.
17 Questions View all
Re-solder/replace power connector with cold solder joint?
USB port/power connector moves up and down when I attach the power adapter and can no longer make a connection no matter what cable I use, so I suspect a cold solder joint, likely from the phone being dropped too many times with the cord attached. If that's what it is, I've re-soldered electronics (not phones) in the past to fix this, but I'm wondering: (1) Is that likely what it is or could something else be loose on the G7? (2) Has anybody ever fixed this issue? (3) How difficult would this be?
Add a comment
1 Answer
Most Helpful Answer
the pins of the port have probably disconnected from the board, could have potentially ripped solder pads aswell
Score 1
Add a comment
Add your answer
Mark Schultz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 32
