Water Damage - Cameras and Flash Issues - Please help troubleshoot
Hi all,
My iPhone X got water damaged. I opened it up and cleaned all corrosion and performed visible inspection with jeweler's loop. The digitizer was bad so I replaced the screen and transplanted the sensor assembly from old screen to new. I am a little suspicious that I might have messed up the sensor alignment, but maybe I am just paranoid. That fixed the digitizer issue but now the front/rear cameras only work when the power flash cable is disconnected. When the rear camera works it is blurry or something is off with the focus. If the power flash cable is connected then the rear cameras will not work. FaceID always complains of issue with the TrueDepth camera in all cases. Leaving rear cameras disconnected does not fix the FaceID or flash issue. Disconnecting the front camera does not fix the rear camera issue. My thought is to try to replace the power flash cable, but wanted to see if anyone else had any experience or ideas on how to further troubleshoot this? Thanks.
