How do I replace the charging port?
Charging port damaged and will not charge with a cord attached. The cord slides out.
First: use a toothpick to check if there is debris. I can't be build up, so pry a little bit. If that doesn't work, you can change the chargeport. Changing the chargeport requires knowledge of fixing phones. Seek a local phone repair shop.
@stephaniel52636 luckily the charging port is soldered to a daughter board. All you have to do is to replace this board. You are looking at something like this As for getting to the board use something like this video
Well this video might be helpful for you :https://www.youtube.com/watch?v=CGX0s44d...
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 51
All Time: 560
Hi @stephaniel52636,
What is the model number of the phone as there is a Moto G Stylus 2021 model and a 2022 model?
by jayeff
